Activity Forums Adobe After Effects Linear light workflow questions
  • Linear light workflow questions
    Posted by Anders Carlsson on April 29, 2010 at 8:30 pm
    Hi all,
    I’ve been playing around with Linear workflow and 32bpc a bit, and I like it. But, I still don’t understand some stuff:
    – I have a project set up with 32bpc sRGB and linearized. I then want do do some keying on the footage, and from what I have heard, it’s best to do that in gamma corrected space (video). So, if I use the Color Profile Converter and set Input to working space and output to srgb, I get a very bright image. Feels like I have a double gamma issue. Should I check any of the linearize checkbox in the color profile converter?
    – What operations do you not want to do in linear space? I’ve heard about keying, what else is there?
    – Say I work in a linear space with Linear EXRs, how do I go ahead to render these out as LOG dpx? Since the source is a EXR, I cant use the Cineon Converter and do a Lin to Log, can I?
    It would be wonderful if anybody could help me out with these questions. Thank you.
    Anders Carlsson replied 16 years, 4 months ago 1 Member · 0 Replies
  • 0 Replies
