Activity Forums Adobe After Effects linear keyframe problem
  • linear keyframe problem
    Posted by Maryanne Hamill on January 8, 2009 at 5:27 pm
    I have several objects in 3d space. There is a camera flying straight thru them. On the camera layer there are simple keyframes on point of interest & position. When it gets to the last keyframe it goes to the position a few frames before then moves backwards. I have checked to make sure that it is set for linear in the keyframe interpolation. There is no extra keyframes hidden any where. I am perplexed. Can anyone give me a suggestion for why this is happening? I am working on CS3 on a G5 if that helps any.
    Thanks in advance, Maryanne
    Peter Van der zee replied 17 years, 7 months ago 2 Members · 2 Replies
  • Maryanne Hamill
    January 8, 2009 at 5:54 pm
    Thanks Dave. I tried your suggestion but my problem was still happening. Then I realized that I was only making sure the last keyframe was linear. I changed the previous keyframe which was set for easy ease in to linear too. Of course it changed it back to a regular keyframe but when I changed it back to easy ease in it worked fine. Thanks again. Sometimes you just need another person to set you on a new path.
  • Peter Van der zee
    January 9, 2009 at 1:11 pm
    I’m glad you solved the problem
    but if it happens again, open keyframe interpolation
    and just put the spatial interpolation to linear
    that will conserve your easy ease out on the temporal interpolation.
    another more precise way is to get a second view (2 views), look for the
    keyframe that does strange things, zoom in a lot and work the spline-handle
    of the keyframe (put it in the same direction of where the camera came from.)
    http://www.zeemotion.com
