Linear disables when keyframes are set?
My actual problem would take a long time to explain so im just going to strip down to the basic info and hope thats enough that someone knows whats happening, and if not ill explain further.
I basically have a property (an xScale of a grid particular emitter) linked to a slider with a linear remapping on it (emitter xScale is the one with the remapping on it) , when i scrub the slider everything works exactly as it should, but when i set a keyframe and try to animate the value of the slider the my emitter just stays the value at which the keyframe was set, wont animate accordingly. Anyone know whats going on there and how to fix it? thanks.
