Activity › Forums › VEGAS Pro › Line sync effect causing bright gaps at the sides
  • Line sync effect causing bright gaps at the sides
    Posted by Samuel Drake on September 26, 2014 at 1:22 pm
    I am having a slight issue with the ‘Line sync’ effect in TV Simulator. When the lines go out of sync little gaps are created at the sides of the screen. The issue is that the gaps are rather bright and this is distracting as the video is rather dark. It is as though there is a white screen behind the main picture which shows through at the sides. Is there a way to change this to black? That way it would not be as noticeable. Thanks!
    Samuel Drake replied 12 years ago 1 Member · 0 Replies
  • 0 Replies
