Activity › Forums › VEGAS Pro › line missing after initializing vegas
  • line missing after initializing vegas
    Posted by Jake Kranz on January 25, 2013 at 12:17 am
    Hi all,
    I recently put vegas (movide studio platinum 10) back to it’s default, and now when I try to put clips together, there’s no color line that shows up when to tracks are touching.
    I tried to go to preferences to see if I could change that, but no luck. When first installed I had those colored lines anyway.
    Any help would be appreciated!
    Jake
    Jake Kranz replied 13 years, 8 months ago 3 Members · 4 Replies
  • John Rofrano
    January 25, 2013 at 4:47 am
    [Jake Kranz] “I recently put vegas (movide studio platinum 10) back to it’s default,”
    How did you do that? Did you hold down Shift+Ctrl while starting it? That should work.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Mike Kujbida
    January 25, 2013 at 1:37 pm
    The F8 key turns Snapping on and off.
  • Jake Kranz
    January 25, 2013 at 2:25 pm
    F8 indeed worked! Thanks a bunch!
    Jake
  • Jake Kranz
    January 25, 2013 at 2:33 pm
    I believe that’s what I did.
    The reason for that was because when I used a plug in such as video FX, the window which pops up that allows you to tweak it, wasn’t showing up. At that point I googled this probelem and found others with the same issue.
    One post suggested to initialize, which I did, and I lost the function of F8 as mike so rightly suggested.
    BTW. initializing did not solve my original problem but unlocking tha taskbar and placing it on the side, revealed the “lost” windown needed to tweak the FX.
    Thanks again!
    Jake
