Activity › Forums › Boris FX Particle Illusion › Line emitter question
Posted by Bill Hamell on October 1, 2006 at 11:12 amIs there a way to move the pivot point of a line emitter?
I would like it to pivot on one end rather than from the center.Thank you,
BillBill Hamell replied 19 years, 11 months ago 3 Members · 5 Replies -
Alan Lorence
October 1, 2006 at 12:25 pmJust move the points that define the line.
Alan.
wondertouch -
Bill Hamell
October 1, 2006 at 1:07 pmThank you Allen,
To get point 2 to revolve around point 1 I would start with point 2 at 0 degrees relevent to point 1 advance few frames set point 2 at 90 degrees to point 1 advance a few frame set point 2 at 180 degres to point one etc., till I get a 360 degree rotation?
Is this correct?
Thank you,
Bill -
Elvis Deane
October 1, 2006 at 4:43 pmIf you move point 1 over the reference point (the smaller point that appears between the two points when you create a line emitter), you can use the Angle graph to rotate point 2 around point 1.
Elvis Deane!
The Apprentice Magician’s Guide to particleIllusion
Bill Hamell
October 1, 2006 at 7:09 pm[Elvis Deane] “If you move point 1 over the reference point (the smaller point that appears between the two points when you create a line emitter), you can use the Angle graph to rotate point 2 around point 1.”
Thank you, Elves I will give that a try. 🙂
Bill
