Activity Forums Adobe After Effects Line drawing ‘sizzling lines’
  • Line drawing ‘sizzling lines’
    Posted by Jay Falk on November 10, 2010 at 8:49 pm
    Can anyone give me a pointer on how to make a cartoon’s lines ‘sizzle’ or ‘shimmer’ like you can see here: https://www.youtube.com/watch?v=nBeWrhC6byo
    Is this just two slightly different versions of the same image or is there a way to do it from one image? I think it is unlikely people spend the time to make two of everything, it’s a very common effect but I have no idea how it is done.
    Any advice greatly appreciated.
    Jay Falk replied 15 years, 10 months ago 2 Members · 4 Replies
  • Kevin Camp
    November 10, 2010 at 9:17 pm
    the scribble effect can do something similar with the right settings, but you’ll need to have vector as masks to use it.
    a simpler approach might be to try the turbulent displace effect. you’ll need to animate the evolutions and lower the size and amount until you start getting a similar look.
    Kevin Camp
    Senior Designer
    KCPQ, KMYQ & KRCW
  • Jay Falk
    November 10, 2010 at 9:41 pm
    Thanks Kevin!
    Now you mention it turbulent displace seems quite a logical place to start – didn’t cross my mind, which is a bit worrying 🙂
    I’ll give that a go right away – I also thought it may be possible by keying out the background kind of badly and then placing a plain white solid behind it – I had to key a wall out from behind an interviewee a while back and his clothing was a very similar color. Along the way I remember dealing with similar shimmering edges on the subject.
    Thanks for such a swift response – I’ll report back on the result.
    Best
    Jay
  • Kevin Camp
    November 10, 2010 at 9:44 pm
    if the art is keyed, say line art from illustrator, you could also try the roughen edges effect.
    Kevin Camp
    Senior Designer
    KCPQ, KMYQ & KRCW
  • Jay Falk
    November 10, 2010 at 9:49 pm
    More Thanks!
    Sounds like this will work out one way or another – really appreciate the tips.
    I’ll post on the results – couldn’t really find much on this anywhere.
    Jay
