Activity › Forums › Apple Final Cut Pro Legacy › Line Cut Trouble
  • John Pale
    December 14, 2007 at 6:29 pm
    The only way I can see to make that work would be to export each sequence as a Quicktime movie, then re-import. Multiclip only works with clips, not sequences. Any other way would require making tons of multiclips.
    I would probably make the quicktimes self contained, as doing reference movies might reduce your performance of multicam playback.
  • Mark Raudonis
    December 14, 2007 at 7:07 pm
    I agree with John.
    You’d have to export a single QT of each angle “sequence” then multiclip those QTs. It will work, but if you need to “uprez” or media manage this project, I’d do a test.
    Mark
  • Winston A. cely
    December 14, 2007 at 8:52 pm
    Thanks guys, but that’s what I was afraid of. I’m multicliping based on TC and it’s not too bad. I am running into a problem now though. Camera 1 Tape 1’s middle section clips are creating unstable multiclips that either won’t allow me to edit the multiclip (only showing one camera) or crashing FCP all together. Fun!
    Thanks again for the replies!
    Winston A. Cely
    Editor/Owner | Della St. Media, LLC
    “If God could do the tricks we can do, He’d be a happy Man.” – Peter O’Toole – “The Stuntman”
    Mac Pro 3GHz Dual-Core Intel Xeon
    4 GB RAM | Final Cut Studio 5.1.4 | Aja Kona LHe
  • Winston A. cely
    December 14, 2007 at 9:16 pm
    Fixed it… very weird TC issue.
    Winston A. Cely
