Activity › Forums › VEGAS Pro › Line appearing through video
  • Line appearing through video
    Posted by John Smith on August 21, 2010 at 5:00 pm
    Hi, I am new to using Sony Vegas, but have been experimenting with rendering to 1440 x 1080 WMV and MP4’s, from my original HD 1980×1080 25fps footage.
    Here is the problem I am encountering:
    I have noticed when the WMV is played on my Vista PC (which has decent RAM and graphics card) that a horizontal line appears every now and again in the clip, as if it is split in half or sliced for a few split seconds, like a flickering. I upgraded my NVidea Gforce 9800 graphics card driver, but this made no difference. I have the latest windows media player too, so its not that either.
    The MP4 played perfectly in Quicktime player on the same pc.
    Ok, I then tested both files on another Windows 9 pc, and they both played perfectly, no splitting or lines appeared, so it can’t be the file can it?
    Then, to confuse matters even more, I tested both files on another slightly slower vista machine, and wierdly, the WMV played perfectly, but it was the MP4 that then had the wierd line and flickering effect.
    When I say lines, I dont mean the interlacing type lines, I mean like one line that appears across as if the picture is split and moved slightly.
    Hope that makes sense to someone out there, but I am stuck as to how to alleviate this annoying problem.
    Any Advice?
    Many thanks!
    John Smith replied 16 years, 1 month ago 1 Member · 0 Replies
  • 0 Replies
