Activity Forums Adobe After Effects Expressions Limiting numbers after decimal point
  • Limiting numbers after decimal point
    Posted by Justin Giudici on September 11, 2012 at 12:59 pm
    Hey everyone, I’m working on a number counter linked to a tracker and want it to just show one number after the decimal(193.4). It worked with Text>Numbers effect but you can’t change the font. I was messing with the .valuetoFixed() but couldn’t get it to work. Thanks for the help.
    x=thisComp.layer("tracker2").transform.position.[0];
    carStart = 0;
    carStop = 800;
    numStart = 1;
    numStop = 195.4;
    ease(x,carStart,carStop,numStart,numStop);
    Justin Giudici replied 14 years ago 3 Members · 3 Replies
  • Klemens Hertha
    September 11, 2012 at 1:12 pm
    I once knew how to do this with expressions but I forgot… 😉
    But why can’t you change the font with the numbers effect?? When you apply the effect to a layer, the first thing you are asked for is the font! Alternatively you can click on “options” in the effects panel!
    Regards,
    Klemens
  • Dan Ebberts
    September 11, 2012 at 1:14 pm
    Try changing the last line to this:
    n = ease(x,carStart,carStop,numStart,numStop);
    n.toFixed(1)
    Dan
  • Justin Giudici
    September 11, 2012 at 1:15 pm
    Klemens you are correct, the little things you always overlook. Thanks
