Activity Forums Adobe After Effects Limiting expression
  • Limiting expression
    Posted by Darren Clevenger on October 14, 2008 at 9:21 pm
    Hi everyone,
    I’m very new to expressions and was looking for some help. I’m animating a cut out mouth and have linked the position of the mouth to my audio amplitude. Is there a way that I can just limit the motion to the Y axis? Currently it’s moving down in a diagonal instead of straight up and down. Any ideas would be greatly appreciated.
    Here’s the expression my pick whip created
    temp = thisComp.layer(“Audio Amplitude”).effect(“Both Channels”)(“Slider”);
    [temp, temp]
    Thanks again for any help.
    Darren
    Darren Clevenger replied 17 years, 11 months ago 3 Members · 3 Replies
  • Mark
    October 15, 2008 at 12:11 am
    Try this:
    [100, (temp*2)] the *2 can be replaced by any number, or link it to a slider.
    I am not in front of AE at the moment, but I am pretty sure that this will work.
    Mark
    PS…do not underline the 100, I only did this to show the 100.
    Mark Harvey
    Senior Editor
    Le Réseau des sports
  • Darby Edelen
    October 15, 2008 at 12:43 am
    If this is being applied directly to your position property then I would recommend:
    temp = thisComp.layer("Audio Amplitude").effect("Both Channels")("Slider");
    m = 2; //multiplier, add a negative sign to reverse direction
    value + [0, temp * m] //current value plus some amount on the Y-axis
    In this case value is the value set in the position property and you are adding to that value only on the Y-axis. You can change the value of m to change the amplitude of the motion based on the audio.
    Darby Edelen
  • Darren Clevenger
    October 17, 2008 at 4:12 pm
    Thanks a lot for the responses! You are geniuses.
