Activity Forums VEGAS Pro Limiter & Parametric EQ Questions
  • Limiter & Parametric EQ Questions
    Posted by Anthony Uccello on June 22, 2010 at 4:15 am
    Hi
    2 questions.
    #1. Is there a way to apply a limiter to the master settings so nothing goes above 0db?
    #2. The Parametic EQ…I’ve been told it can help clean things up when there is speaking and music (apparently it makes the music less sharp when you speak but lets the music still be heard).
    However I have no idea what is going on when I open this audio plug in.
    Is there a tutorial on this or a simple way to explain how I can use it to set the music to not overpower a person speaking over it (in a distinct track) but still keep the sharpness of the music? What are some standard settings that allow this?
    Anthony Uccello replied 16 years, 3 months ago 2 Members · 2 Replies
  • John Rofrano
    June 22, 2010 at 11:48 am
    Add Wave Hammer Surround to the master audio bus and use the [Sys] Master for 16-bit preset.
    Just add a Volume Envelope to the music track and lower the music while the person is speaking.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Anthony Uccello
    June 22, 2010 at 2:15 pm
    Very kewl thanks!
