Activity Forums Adobe After Effects Expressions Limitations with Math.pow?
  • Limitations with Math.pow?
    Posted by Allen Ellis on February 13, 2008 at 7:55 pm
    Whenever I try to use decimals or fractions for my exponent in Math.pow I get this error: Invalid numeric result (divide by zero?)
    Math.pow(2,2.5), or Math.pow(2,1/3) both yield this error.
    Is there a way for me to do this?
    Thanks.
    Allen Ellis replied 18 years, 7 months ago 2 Members · 6 Replies
  • Dan Ebberts
    February 13, 2008 at 9:35 pm
    Both of those work fine for me when applied to a slider. What does the rest of your expression look like?
    Dan
  • Allen Ellis
    February 14, 2008 at 1:10 am
    You’re right – it does.
    The expression is applied to a point control. Here is the code:
    x = this_comp.layer(“X”).effect(“X”).param(“Slider”);
    y = Math.pow(x,3); // y = x^3
    [x,y]
    It complains about the error on the last line, not line 2.
    Here is the project file:
    https://www.allenellis.com/public/Graph.aep
    Look at layer 3: “Point Control”.
    Thanks in advance.
  • Dan Ebberts
    February 14, 2008 at 1:25 am
    Hmmm… that’s strange. I don’t get any expression errors when I open the project, and it renders fine. I notice that it’s a 5.5.1 project, so I’m wondering if it’s something that got fixed between 5.5 and 7.0 (the oldest version I have installed right now).
    Maybe somebody can try it in 5.5.
    Dan
  • Allen Ellis
    February 14, 2008 at 1:48 am
    Well that project opens fine for me, too – I get the error when I change layer 3’s expression to be
    y = Math.pow(x,2.5);
    Or some other decimal/fraction number.
    Sorry that I forgot to mention that. I didn’t want to submit a project with errors because I assumed it wouldn’t show the error that way.
  • Dan Ebberts
    February 14, 2008 at 3:32 am
    Ah, OK – here’s the deal. When you feed Math.pow() a negative number for x and a non-integer value for y, it tries to generate an imaginary or complex number, and the actual result you get is NaN. That’s what’s causing AE to throw the error. So – you’ll need to do something like this to get the curve you’re after:
    if (x < 0){ y = -Math.pow(-x,2.5); }else{ y = Math.pow(x,2.5); } [x,y] Dan
  • Allen Ellis
    February 14, 2008 at 4:34 am
    Thanks so much – that’s exactly what I needed.
    I’m running into other similar issues now but they’re more minor and I think I’ll know how to deal with them now. Thanks again :).
