Activity Forums Apple Final Cut Pro Legacy Limit SmoothCam to In/Out points
  • Limit SmoothCam to In/Out points
    Posted by Tac Tacelosky on March 8, 2010 at 2:52 pm
    I need to put the SmoothCam filter on a 3-second clip, part of a 30-minute file. Even though the in/out points are set to just the few seconds I want, the filter wants to analyze the whole file (which is estimated to take over 2 hours).
    One solution is to render the few seconds that I want, then import that small file, the apply the filter to that new, tiny file. While this will work, it certainly doesn’t seem very elegant. Is there a better way?
    Tac
    Bryan Mailer replied 13 years, 9 months ago 6 Members · 8 Replies
  • 8 Replies
  • Edward Kulzer
    March 8, 2010 at 5:23 pm
    Not sure if g-g-g “Limit selection” would work for applying Smoothcam; Smoothcam ALWAYS sources back to the entire clip duration.
  • Tac Tacelosky
    March 8, 2010 at 5:40 pm
    What is g-g-g?
  • John Pale
    March 8, 2010 at 6:01 pm
    Export the clip using your in and out points as a Quicktime movie (same as source). Reimport that and apply Smoothcam. This is actually what the manual tells you to do
  • Jeremy Garchow
    March 8, 2010 at 7:09 pm
    You can also send it out to Motion (don’t embed content) and analyze there. Then simply render out a movie and replace.
    Jeremy
  • John Pale
    March 8, 2010 at 8:02 pm
    [Jeremy Garchow] “You can also send it out to Motion (don’t embed content) and analyze there. Then simply render out a movie and replace.
    Even better. Thanks for that one.
  • Edward Kulzer
    March 8, 2010 at 10:44 pm
    Triple-G is the FCP Keyboard Shortcut to apply a filter to a chosen section of a clip.
  • Kit Mackenzie
    October 22, 2010 at 2:41 pm
    Aware this is an old topic but it helped me out so thought I’d post what I found to be a good method.
    Follow method described in post marked as ‘Solution’ however if you are still exporting a fairly long clip and want to save on Hard Drive space you don’t have to make the movie self-contained, the method works with reference movies
    Regards
  • Bryan Mailer
    November 21, 2012 at 7:53 am
    I couldn’t get this to work. Can’t find Smoothcam in Motion and Final Cut still uses the whole file when I roundtrip a clip.
