Activity Forums Adobe After Effects Expressions Limit movement to Comp dimensions
  • Limit movement to Comp dimensions
    Posted by Andreas Woelfl on September 22, 2016 at 10:25 am
    Hello everybody,
    I am trying to write a script that allows me to grab and move an element inside the comps borders, but only within the comp’s width and height. So even if I would drag the element outside the comp it would stay at the border of the comp.
    Please find the script that I added to the object in my comp below.
    With the script that I have so far it works visual wise. So the square gets stuck on the comp border when ever I try to drag it outside the comp. The only problem I have is that it seems that if I drag the square for example 5000px to the right outside the comp it stucks directly at the border. But when I want to drag it back in the middle I have to drag it at first 5000px back to the left until I can see the square moving inside the comp.
    Can anybody tell me if I need an adjustment to my code or maybe a complete other aproach?
    Thanks for the help!
    xPos = transform.position[0];
    if (transform.position[0]>1920) {
    xPos = 1920
    if (transform.position[0]<0) {
    xPos = 0
    yPos = transform.position[1];
    [xPos, yPos]
    Xavier Gomez replied 9 years, 12 months ago 2 Members · 2 Replies
  • Xavier Gomez
    September 22, 2016 at 12:40 pm
    An expression can bypass the value as you did, but cannot prevent you to set a given value.
    I dont think there is a way to do what you want.
    Note: you could shorten the expression, and make it valid for any comp size, as follows:
    pos = value;
    pos[0] = clamp(pos[0], 0, thisComp.width);
    pos;
    Xavier
  • Xavier Gomez
    September 22, 2016 at 12:47 pm
    You could also hit P to reveal the position property of the layer, then either :
    right click the position property, > reset to recenter,
    or shift+scroll the x value to scroll faster.
    Xavier
