Activity Forums Adobe After Effects Expressions Like the iphone Animation: Leading and Kerning with Scripts
  • Like the iphone Animation: Leading and Kerning with Scripts
    Posted by David Escurriola on July 1, 2011 at 4:31 pm
    Hallo everybody
    I’m doing an animation where a finger should scroll through the numbers like it works on the iphone.
    This Numbers will should at -50’000 and end up at 2011. I’ve been using some scripts posted in Creativecow and other webages but I will like to be able to change the leading (distance between lines) and the kerning (distance between every single character). I’ve been fighting with this settings for a very long time. Do you know how to add those slider controllers? is added aswell two pictures who shows the final comp. My second problem is how the animate the values with thousand apostroph inbetween (like 50’000 or 4’000).
    Thank you very much for your help
    Greetz from Zurich
    David
    Link to the AFX CS5 File: 2497_numbersexpression.aep.zip
    David Escurriola replied 15 years, 2 months ago 2 Members · 5 Replies
  • Dan Ebberts
    July 1, 2011 at 5:47 pm
    This should give you the apostrophes (assuming n is an integer):
    n = Math.round(effect("Slider Control")("Slider"));
    pre = n < 0 ? "-" : "";
    s = ""+ Math.abs(n);
    str = s.substr(-s.length, (s.length-1)%3 +1);
    for (i = Math.floor((s.length-1)/3); i > 0; i--){
    str += "'" + s.substr(-i*3,3);
    pre + str
    As far a leading and kerning, expressions have no access to those (scripting either, for that matter). The closest you could come would be to add Line Spacing and Tracking animators.
    Dan
  • David Escurriola
    July 1, 2011 at 7:39 pm
    Hi Dan. Thanks for your soon replay. I tried your expression placing it at the Text Source and tested on several ways like replacing all the “n” through 1000 (with and without apostrophe) but It’s not working. “Unterminated string constant Expression disabled” is what After Effects tells me. Can you please explain me, where did I go wrong?
    It’s quite weak I can not set the kerning with different values, since the apostroph need less space than a zero. But ok, I guess I can live with it.
    Now regarding of Spacing. I don’t use spacing as such, since every line is on a different layer. Look at he script underneath: i’ve been editing the value of “2500” by hand, so that the layer underneath has a value of 2700, 2900 and so on. But the script “thisComp.layer(index – 1)” doesn’t work
    Did you opened the sequence I sent? I guess you will see quite fast what I mean.
    Thanks very much
    David
    x=comp("MasterController").layer("Null 1").effect("Slider Control")("Slider") + 2500;
    range=300; //range when Z begins
    center=thisComp.width*0.5; //center of comp on X axis
    distance=x-center;
    Zdist=400;
    if (x &lt;= center ){
    Zpos=ease(center+distance,center-range,center,value[2],value[2]-Zdist);
    }else{
    Zpos=ease(center+distance,center,center+range,value[2]-Zdist,value[2]);
    [x,value[1],Zpos]
  • Dan Ebberts
    July 1, 2011 at 8:15 pm
    This doesn’t work?
    n = 1000;
    pre + str
    Dan
  • David Escurriola
    July 1, 2011 at 8:33 pm
    Dear Dan
    I have to confess, that my expressions skills are to limited to implement your expression in the right place.
    This was the reason, I asked you if you had a look into the afx file i sent to you.
    thank you veeeery much for your help
    david
  • David Escurriola
    July 7, 2011 at 6:54 am
    Dear Dan
    Yes, it is working. Thanks very much for your support. But the result was due of the impossiblity of edit the kerning at the apostroph not usable. So I had to do it manually.
    Best wishes
    David
