Activity Forums Adobe After Effects Lightsaber question..
  • Lightsaber question..
    Posted by Baozer on July 3, 2007 at 12:13 am
    Hey,
    Does anyone know how to obscure more than one person using Andrew Kramer’s method in
    https://www.videocopilot.net/videotutorials/saber2/index.htm (?)
    For example, if you were making a film, and at one point one person is obscuring the saber and a few seconds later, he/she was obscuring it again, how would you go about doing that? I was going to interpret the method and do it the same way for multiple people but I wasnt sure. Any inputs would be greatly appreciated.
    Shadow hide you..
    David Yeaman replied 16 years, 9 months ago 3 Members · 3 Replies
  • Scott Roberts
    July 3, 2007 at 5:26 am
    I’d probably mask off the saber when it’s behind the other guy, since it probably only does that for a few frames at a time.
    Color Grading presets for After Effects, Premiere, etc., plus free presets and more.
    LITTLE BLACK BIRD – PROFESSIONAL VISUAL EFFECTS
    https://www.littleblackbird.com
  • Baozer
    July 4, 2007 at 6:46 pm
    Thank you. So right before the saber is obstructed, you create a mask for the part that is obscured and change the mode to subtract? And create keyframes?
  • David Yeaman
    December 4, 2009 at 6:44 am
    Hi, I’m having this problem too. I tried putting a subtract mask on the lightsaber but it wont behave properly (i’m guessin because the lightsaber preset itself affecting the solid interferes with the mask.) Is there anyway to create a mask on a separate layer (like a null) and have it affect the lightsaber?
