Activity Forums Adobe After Effects Lights stopped working?
  • Lights stopped working?
    Posted by Neil Robinson on February 3, 2009 at 11:55 am
    Hello, Can anyone help me please. Lights have stopped working in After Effects CS2 PC. I can import lights from old projects when it was working but when you add a new light it doesn’t work whatever settings you use.
    Any Ideas?
    Cheers
    Neil
    Neil R
    Jean Mathis replied 14 years, 9 months ago 3 Members · 3 Replies
  • Jon Hutton
    February 4, 2009 at 12:42 am
    This probably isn’t your solution, but just remember that lights only work on 3D layers, are the layers you want your lights to work on set to 3D?
  • Neil Robinson
    February 4, 2009 at 12:01 pm
    The layer is set to 3D, see attached image.
    Neil R
  • Jean Mathis
    November 27, 2011 at 11:58 am
    I have to resurrect this thread because I had a similar case today. In the comp of a project where there were a bunch of comps, just one comp had its light layers stop working. I had a save of the project where the lights would be working so I imported it open the comp where the lights worked copied all the layers and pasted them in the comp where the lights would not work (before I deleted al the layers in there)
    and guess what, the lights would not work again… I finally copied the comp and replaced the whole comp and then it did work. The only suspicion I have is that this was a project converted from CS4 to CS5 other than this I wouldn’t guess coz I checked everything and having worked with AE for more than 15 years I know quite a bunch of tricks…
    Any Idea?
    (we’re at a thousand miles from a “3D layer switch on or off” issue here, I guess…)
    Jean
