Activity Forums Adobe After Effects Lights Problem – I don’t see them
  • Lights Problem – I don’t see them
    Posted by Mari Jenkins on August 18, 2012 at 3:04 pm
    Read a number of other posts on this, but the only response I found was “uh, check your settings,” which doesn’t help a ton. 🙂
    I’m using After Effects after having some experience in Combustion. When I add a light, I don’t see it in the composition view. My lights are switched to Cast Shadows, and my layers switched to Accept Lights/Cast shadows/accept shadows.
    I can turn off all lights entirely, and still see everything in the scene. What am I missing here? I’m sure it’s a simple stupid setting somewhere, but I haven’t found any posts identifying it. Watched several tutorials in hopes to seeing them set up whatever it is I’m not doing, but no luck. Anyone?
    Thanks in advance to whatever kind person tackles this.
    Mari Jenkins replied 14 years, 1 month ago 4 Members · 5 Replies
  • Ronn Trevino
    August 18, 2012 at 3:56 pm
    There are 2 settings when dealing with lights. The lights themselves & whatever the lights is shining on. Make sure your layer is set to “accept lights” that’s why you still see stuff when the lights are off. They ( the layers the lights are illuminating) more than likely are not set to accept lights.
  • Chris Brett
    August 18, 2012 at 4:16 pm
    Hi Ronn –
    – not completely sure about this as I’m new to this platform myself but try switching all the layers as ‘3D layers’ ( if not already ) and see if that makes any difference …..
    …………… some things only work on 3D layers.
    ————————chris brett // uk
  • Chris Brett
    August 18, 2012 at 4:18 pm
    Hi Mari –
    Sorry Ronn for erroneous reply — got the wires crossed …..
  • Vishesh Arora
    See as you have said that you can’t see your light in composition, Make sure your its not an ambient light because ambient lights are not visible. Change the light type to something else to make it visible.
    Or check whether you have enabled Layer Controls. Just press “Cntl/Cmnd + Shift + H”. It will make lights visible if any.
    Secondly, Make sure you just don’t turn off lights by hiding . Try to bring the intensity to zero.
    Also Check that your “Draft 3d” Button(right hand side of the search bat in timeline) is disabled.
    Vishesh Arora
    VFX and Motion Graphics Artist
    https://digieffects.wordpress.com
  • Mari Jenkins
    August 18, 2012 at 8:08 pm
    Thank you. I didn’t realize about the Draft 3D function. An enormous help. I’m gonna go post it on other peoples’ threads about this.
