Activity Forums Maxon Cinema 4D Lights inside mograph cloner not in AE composit
  • Lights inside mograph cloner not in AE composit
    Posted by Louis Marino on September 18, 2008 at 11:27 pm
    I’ve got a scene where the is a cloner object with a sound effector, which is moving an object. There is a light inside this object, which I was planning to use as a marker, when I saved an after effects compositing file. But it’s not in the scene when I import it into after effects (the other lights which aren’t affected by mopgraph are in the scene). Im assuming that I need to bake the mograph animation in some way? Tried using the cache tag but no luck. Anyone got any ideas? Thanks!
    Louis Marino replied 18 years ago 1 Member · 0 Replies
  • 0 Replies
