Activity Forums Adobe After Effects Lights in pre-comp affecting main composition
  • Lights in pre-comp affecting main composition
    Posted by Daniel Christie on April 14, 2009 at 4:53 pm
    Hi guys,
    Just installed CS4 qnd everything is going great, but I just tried to render a comp at best quality settings and suddenly the 3D layers in the main comp are lit by the lights in a nested precomp (which, by the way, is the bottom layer in the main comp. This was not apparent in the previews. Have I missed something?
    Many thanks,
    Daniel
    Daniel Christie replied 17 years, 5 months ago 3 Members · 3 Replies
  • Jeff Dobrow
    April 14, 2009 at 5:09 pm
    If you have continiously rasterize turned on, then the lights will pass through into the current comp from the pre-comp.
  • Darby Edelen
    April 14, 2009 at 8:58 pm
    [jeff dobrow] “If you have continiously rasterize turned on, then the lights will pass through into the current comp from the pre-comp.”
    Actually, when you collapse transformations/continuously rasterize, the lights in the pre-comp will be ignored in the main comp. However, if you have the collapse transformations layer switch off the lights should not affect the layers in the main comp either.
    I have no idea how this is happening. Can you post a picture of your timeline?
    Darby Edelen
  • Daniel Christie
    April 15, 2009 at 1:45 am
    Thanks for the replies. It turns out the error was completely human. I was not previewing a light which was hidden in another one of the precomps because I was in draft 3D mode.
    Thanks anyway.
