Activity Forums Maxon Cinema 4D Lightning problem
  • Lightning problem
    Posted by Khangai Khangai on June 25, 2015 at 10:45 am
    Hello guys, i’ve GSG light kit pro v.2 and when i adjust LinearDayLight’s sky brightness, that affects in the room /i created 1 room for interior/. I just wanna see sky brightness through the window.
    And i tried regular light and created 1 cube object. That light affects inside of cube too… What’s this problem, i wish that cube walls block the light, how can i ? anyone can help me ? thanks 😀
    Khangai Khangai replied 11 years, 2 months ago 2 Members · 2 Replies
  • Joachim Holler
    June 26, 2015 at 7:52 am
    Not exactly sure about your setup, but you could try putting a compositing tag onto your cube. In the “Tag” settings, untick “Seen by GI”.
    Should the outside of the cube be lit?
  • Khangai Khangai
    June 26, 2015 at 12:54 pm
    Thanks for your reply, i just tried compositing tag as you said, but it didnt work well 🙁
    in 1st image: sky brightness around 200%
    in 2nd image: sky brightness around 50%, as you see that affects in room, i just wanna see sky through the window 😀
    i used compisiting tag on both image
