Hi Rick…
I’m not sure of any actual plugin to do what you want (although there may be), but I’ve always found fairly realistic lightning strikes easy enough to do without it.
Normally, I just way crank up the brightness and lower the contrast for about two frames, then skip a couple of frames (i.e., leave them normal), then do it again to one additional frame. That looks pretty good. Or you can make double strikes, or even triple. It’s also helpful to skew your color grading a bit to the blue side on those affected frames as well.
You can take it a step further, too, if there are objects or people in the room that you want to see the effect more on. Just export those affected frames as stills (.bmp files or whatever), then take them into Photoshop so you can tweak on them, giving people and objects more of the effect on select areas, such as one side of a person’s face. Such as, one glow a bit heavier on the side of someone’s cheek, another on the nose, one on the forehead, etc… obviously, from the direction of the light source (window, or whatever).
It’s easy breezy, maybe five minutes.
T2
__________________________________
Todd Terry
Creative Director
Fantastic Plastic Entertainment, Inc.
fantasticplastic.com
