Activity Forums Boris FX Particle Illusion Lightning 2 The Return :-)
  • Lightning 2 The Return :-)
    Posted by Bill Hamell on September 2, 2006 at 7:36 pm
    If you liked Lightning you’ll love The sequel, Lightning 2. 🙂
    Different URL same great content. 🙂 (I am in the process of switching over domains.)
    https://latentimageproductions.net/pi/lightning2.zip
    I used the 512×512 textures again I had already started them so I used them.
    I did try to resample them in PI, it did not work out at all.
    Next one I will give it a go with a smaller texture size.
    As always comments welcome.
    Bill
    Cinematographers bring Shadow to Light
    Mahmud Khan replied 20 years ago 2 Members · 4 Replies
  • Bill Hamell
    September 3, 2006 at 10:47 pm
    I went in frame by frame and adjusted the bolts so there are no dead ends in mid strike.
    I think it looks cleaner than version 2 that
  • Mahmud Khan
    September 12, 2006 at 9:16 pm
    Is there a way that I can change this emitter in order to make it look like the electrical discharge is heading from one location to another?
  • Bill Hamell
    September 16, 2006 at 2:26 pm
    You could export the shape, rotate each image to the proper angle and create a new shape or you can change the angle of the Layer so the bolts shoot horizontal rather than vertical.
    Then position and size the emitter as needed.
    Bill
  • Mahmud Khan
    September 16, 2006 at 9:40 pm
    I don’t really follow….
    Can someone just teach me how to make an emitter? From scratch?
