Activity Forums Maxon Cinema 4D Lighting/shadow help
  • Lighting/shadow help
    Posted by Donna Arbogast on October 15, 2009 at 12:21 pm
    Building a scene in Cinema 4D v 10.5. I have a sky object, but am unable to activate AO. It’s grayed out. So I added an omni light; I’ve tried various settings but no matter what settings I try, the shadows are really harsh and unrealistic. Any suggestions? Why would my AO be grayed out? I put a “sky” material on the sky object; should I remove it?
    Donna Arbogast replied 16 years, 11 months ago 2 Members · 2 Replies
  • Randy Johnson
    October 15, 2009 at 6:43 pm
    AO is part of the Advanced Render Module so I have to ask, do you have that module?
    I don’t think you have to have a sky for AO. You need it for Global Illumination.
    When faking AO or GI I find using an array of 4-7 lights over each element in the scene in addition to a single omni (w shadows) in the sky. (Non of these would be set at a high strength.)
    Try setting your shadows to soft and if need be use negative lights in places to remove unwanted high lights. I have seen really great renders with out AO or GI so long as you take the time to light.
    Good luck
    /Randy
  • Donna Arbogast
    October 15, 2009 at 9:53 pm
    Excellent! So much better. Thank you.
