Activity › Forums › Lighting Design › Lighting w/ Softboxes in Smaller Shoots
  • Lighting w/ Softboxes in Smaller Shoots
    Posted by Phil Muri on February 14, 2006 at 12:07 am
    Howdy Cowpokes,
    Can anyone point me to information sources which center around lighting with Softboxes for video?
    Can Softboxes be the centerpiece in a lighting setup?
    My situation is that the shoot is a small one and (this is only a presumption on my part) maybe a Softbox would facilitate things with tighter setup times and where the crew is smaller
    Frank Otto replied 20 years, 7 months ago 2 Members · 1 Reply
  • Frank Otto
    February 14, 2006 at 4:58 pm
    I use softs all the time for interview and product shots. The only problem I have in very small rooms is spill from a too wide source which can be overcome with egg crate grids or flags and cutters – or even a flag made of “blackwrap”- a black annodized aluminum foil.
    Three point lighting isn’t etched in stone. Often I use just the softbox as the only “source”, placing it 30deg. off center so I get a darker side of the interview. Occasionally, if the shot needs separation I’ll hit it with a 150-300w. fresnel if I don’t have a natural source in the room like a table lamp or window.
    Alternatively, pointing that 300w. fresnel to the wall with a wash/slash/poof/glow/(insert your favorite look here) works if you don’t want a backlight or don’t have the room for separation. You can also use color gel on the light to accent the room or the person.
    Cheers,
    Frank Otto
