Activity › Forums › Maxon Cinema 4D › Lighting Question
Lighting Question
Posted by Gary Smith on March 22, 2010 at 3:43 amAnybody have any ideas on what lighting settings could be used to achieve a lighting effect similar to the following renders? I thought it was just turning Global Illumination on, but I couldn’t ever quite achieve the same effect in c4d.
https://ceskills.com/ARTWORK/38.html
https://www.ceskills.com/raikiboy/img/Extras/Raiki_wallpaper04_1280x800px.jpg
Thanks for your help!
Adam Trachtenberg replied 16 years, 6 months ago 4 Members · 8 Replies -
Adam Trachtenberg
March 22, 2010 at 2:42 pmIt could be GI or it could be ambient occlusion. In either case you’ll need a sky dome to provide that even lighting. So with GI, you would create a generic sky object, and with AO you would check the “use sky environment” box in the effect properties. AO can also be done per material.
You’d also want to turn off the specular channel for all of your materials.
Jeremy Allen
March 22, 2010 at 2:43 pmI’m pretty sure they are using ambient occlusion for that. Could be wrong though, I’m still kinda new to C4D myself.
8core MacPro, 3.0 GHZ, 10GB RAM, OSX 10.5.6C4D 11.5
AE CS3
FCP 6.0.1 -
Adam Trachtenberg
March 22, 2010 at 2:52 pmI should add that, if you use AO instead of GI, you’ll have to add lights to create that even lighting. You can do that by cloning lights onto a half sphere, or using an array (or several) of low intensity lights.
Gary Smith
March 22, 2010 at 3:08 pmThanks for the help! I’m getting closer.
Here is a render of a sphere. The shading around the edges is way too dark. I think the low intensity lights in a dome will do the trick, but haven’t tried it yet. Any other tips to lighten the dark shading?
https://i39.tinypic.com/161nhx3.jpg
Thanks in advance.
Mark Walczak
March 22, 2010 at 8:16 pmJust to throw in another vote for Ambient Occlusion, I did a similar project here:
I simply used solid colors (with no other material channels active) and, of course, AO. The half-dome effect certainly works, but I’ve had some trouble with parametric objects looking really faceted…
I’m glad you found something that works!
https://vimeo.com/explosivegraffix
Some contents or functionalities here are not available due to your cookie preferences!This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
Adam Trachtenberg
March 25, 2010 at 2:58 amGlad it worked out.
For future reference, there are a couple other things you can do:
* use a light or environment object with the ambient option enabled. Use of ambient lighting is frowned upon a lot because it tends to produce a flat render, but it can be effective in low doses;
* lower the density of your shadow-casting lights’ shadows;
* reduce your lights’ contrast setting;
* mix a bit of luminance into your materials;
* use fill lights to simulate bounce lighting (fake GI).
