Activity Forums Adobe After Effects Lighting on comp within comp
  • Lighting on comp within comp
    Posted by Trippp on September 4, 2007 at 9:54 am
    Hi All,
    I’m creating a box in 3-D space within a comp and then lighting it. Then I’m bringing my comp into another comp that is also in 3-D space. Everything is fine, except my lighting doesn’t seem to be following into the second comp.
    Is there a step that I’m missing or box I’m not clicking? Hopefully so. Not really looking forward to re-lighting everything in the final comp.
    Mark
    Finalrenderfilms replied 19 years ago 3 Members · 4 Replies
  • Roland R. kahlenberg
    September 4, 2007 at 1:11 pm
    This is one area where AE just breaks apart.
    Nested Lights get nuked in the main comp. Don’t ever light naything in a precomp.
    Your best bet is to do all the lighting in the main comp or copy the light(s) into the main comp and work over there.
    Cheers
    Roland Kahlenberg
    https://www.broadcastGEMs.com – Adobe After Effects project files
    https://www.myspace.com/rorkrgbspace
  • Trippp
    September 4, 2007 at 1:36 pm
    Thanks, Roland. Not exactly the answer I wanted, but knowing this makes it easier to go forward and avoid the same mistakes again.
    Have a great day.
    September 4, 2007 at 1:44 pm
    I should also have mentioned that if your main comp doesn’t have a light layer then things are okay.
    Therefore, you may want to have a 3rd comp – a final comp that doesn’t have any camera or lights where these two 3D comps can reside – ensure that you have Collapsed Transformations switched on for the nested 3D comps. The downside is that I really don’t know how lights from the two comps are going to react to each other.
    I’m not on an AE-capable PC right now, so you’ll have to run quick tests to see if it’s a viable option.
    Cheers
    Roland Kahlenberg
  • Finalrenderfilms
    September 4, 2007 at 5:17 pm
    Trippp….huh..I knew a kid in elementary school by the same name…his real name was Jack. lol, you aren’t him, are you? lol…sorry for the off topic post.
    Mark
    Final Render Films
