Activity › Forums › Adobe After Effects › lighting on a text
  • Reza Rezai
    December 15, 2007 at 12:30 pm
    lighting on a text(ok)
  • Steve Roberts
    December 15, 2007 at 6:37 pm
    Buy Trapcode Lux?
  • Darby Edelen
    December 15, 2007 at 10:58 pm
    Unfortunately, Lux won’t allow you to do something as complex as that. The rays of light are taking the shape of the text, which makes it look as though the text is being projected onto the wall. Lux doesn’t allow you to specify layers to block the light rays… although that would be cool =)
    You can get this look with a technique that Filip Vandueren came up with, the set up is rather involved (there are some expressions, so be warned) but it’s a pretty killer look:
    https://forums.creativecow.net/readpost/2/891127
    Get to know your new best friend Radial Blur (;
    Darby Edelen
    Designer
    Left Coast Digital
    Santa Cruz, CA
  • Sam Moulton
    December 18, 2007 at 1:39 am
    You could apply shine to a 3d text layer and adjust the source point to achieve the effect in AE.
