Activity Forums Lighting Design Lighting intervews
  • Lighting intervews
    Posted by Ben Edwards on April 8, 2017 at 8:38 pm
    Hi. Previously I was using open faced lights but have now got a couple or Fresnels. Was wondering roughly what diffuser level and type a Fresnel was equivalent to (compared to open faced).
    Ultimately what I think I want to go for is something like what I did get on an open faced with a 1/4 (lee 251) defuser or a Hollywood or Opel frost but understanding the level of diffusion I would get with a Fresnel would be a good start.
    Or what other slight delusion was good for fresnels.
    Ben
    Ben Edwards – Freelance Picture Editor
    https://www.funkytwig.com
    i5 3550 3.3Ghz, Windows 7 / Mac Lion, Nvida 550 Ti, 16GB Mem
    Ralph Chaney replied 8 years, 11 months ago 5 Members · 6 Replies
  • Erik Anschicks
    April 11, 2017 at 4:37 am
    Your post title is about lighting interviews, so given that and your questions about diffusion qualities, I’d imagine you’re talking about using these fresnels to light the people themselves? Or do you mean lighting the backgrounds/other items in the frame?
    Fresnel lenses don’t really “diffuse” light in the same way that actual diffusion does. They really just provide directionality, shape, and controllability to the raw lumens coming from the lamp itself. To directly answer your question, using a fresnel raw with no diffusion on people for an interview is not going to be a whole lot better than an open-face unit. Might be just the SLIGHTEST bit softer, maybe, but it’s going to be pretty hard lighting either way.
    Unless it’s the only option you have, putting a fresnel through diffusion largely defeats its purpose, which is to provide you with a controllable, harder source that doesn’t spill where you don’t want it to. The tapered, focused beam of light is largely nullified by all but the lightest of diffusions, and it just isn’t the most efficient use of the unit.
    This is why you don’t often see fresnels going through a softbox, it’s much more efficient to just use an open-face unit with diffusion. All the fresnel is really going to do at that point is eat up light unnecessarily as all its benefits are largely negated. It’s a better option to shoot an open-face light through thicker diffusion to light people for interviews, provided, of course, that softening the light on the person is the goal.
    IMO fresnels are best suited to light backgrounds or set elements, where you can “paint” with light without diffusion scattering the light everywhere. On the occasion where I want to take a BIT of the edge off the light but still want to retain the overall beam shape and directionality, I’ll use a very subtle, very light bit of diffusion like Hampshire Frost or something akin.
  • Mark Suszko
    October 3, 2017 at 4:10 pm
    What would you think about using the fresnels targeted at bounce cards, instead of going direct thru diffusion? I had some good luck putting an HMI keylight behind the talent and bouncing it off a foam core panel on the camera side, the HMI in that position had just enough spill to act as rim/backlight AND keylight in one instrument.
  • Todd Terry
    October 3, 2017 at 5:05 pm
    [Mark Suszko] ” I had some good luck putting an HMI keylight behind the talent and bouncing it off a foam core panel on the camera side, the HMI in that position had just enough spill to act as rim/backlight AND keylight in one instrument.”
    That has been my go-to trick for years. I posted a “how to” pic on the COW years ago that I would look up if I were not so incredibly lazy… umm I mean busy… today.
    The only real downside is lugging around an HMI and ballast, which we don’t do much anymore… we are almost totally in the stinger-less LED world now. But I think I’m about to buy another LED, Movofilms finally has an affordable bigass LED fresnel that is about as powerful as a 1200w HMI (and can run on batteries, two bricks)… looks to be almost a clone of the much much more expensive instrument from Aadyntech. Should be able to do the same kind of setup with that.
    T2
    __________________________________
    Todd Terry
    Creative Director
    Fantastic Plastic Entertainment, Inc.
    fantasticplastic.com
  • Mark Suszko
    October 3, 2017 at 5:50 pm
    “I learned it from YOU, dad!!!”
  • Todd Terry
    October 3, 2017 at 6:13 pm
    I hope I’m not the only one who gets that.
    https://youtu.be/Y-Elr5K2Vuo
    T2
    Todd Terry
    Creative Director
  • Ralph Chaney
    October 4, 2017 at 6:30 am
    Parents who light interviews with fresnels have children who…
    -> Ralph
