Activity Forums Adobe After Effects lighting inside a cube
  • lighting inside a cube
    Posted by Greg Chattwood on February 20, 2008 at 1:00 am
    essentially i’m trying to make a 3D cube act like a light bulb, and have tried using the point light inside the cube, but can’t seem to get it to work
    any help would be greatly appreciated
    David Bogie replied 18 years, 7 months ago 3 Members · 2 Replies
  • Lyrad Boots
    February 20, 2008 at 9:08 am
    How about turning the cube opacity to around 60% and then putting an omni light onto a adjustment layer.?
  • David Bogie
    February 20, 2008 at 8:15 pm
    You can’t create an object that emits light. You can turn the faces of the cube into objhects that act as gobos or filters but that’s not the same thing as a glowing panel that produces light that will illumine another object.
    Back in the olden days, we’d simply create a light and parent it to the object. You’d adjust the shadow dispersion and color of this light to emulate the cube’s attributes.
    bogiesan
