Activity Forums Broadcasting Lighting in a Color Grading room
  • Lighting in a Color Grading room
    Posted by Mathieu Marano on January 14, 2008 at 2:52 pm
    Hi everybpdy,
    I’m setting up a new color grading room for TV Show and commercials. I was wondering if it was better to get a dark room or a bright D65 backlight?
    Most of the work we do is SD but the room will be setup for HD work as we expect to increase our HD costumers.
    Mathieu Marano
    Ermi Apostoli replied 14 years, 10 months ago 3 Members · 3 Replies
  • Terence Curren
    January 16, 2008 at 5:15 pm
    Traditionally you would have a dark room with a 65K light behind the monitor that was 10 percent of the peak white of your monitor.
    With LCDs, the world can change. The blacks which suck on an LCD, start to look better as the ambient light in the room comes up. The exact opposite of the CRT.
    in other words, since we are in a transitional stage without appropriate monitors, all bets are off for the time being. What type of monitor are you going to be using?
    Terence Curren
    http://www.alphadogs.tv
    http://www.digitalservicestation.com
    Burbank,Ca
  • Mathieu Marano
    January 16, 2008 at 6:16 pm
    We are going with a 24in LCD CineTal or a TVLogic. Both are LCD.
    Mathieu Marano
    online editor – motion graphics – Post-prod director
    Directeur technique de post-production
    Le Bureau de post production
    Administrator of the Montreal Final Cut User Group
    http://www.finalcutmtl.org
  • Ermi Apostoli
    November 16, 2011 at 11:34 am
    What is the correct colour grey to be painted behind a LCD monitor in a colour timing room
