Activity › Forums › Lighting Design › Lighting for stop motion animation
  • John Sharaf
    August 14, 2006 at 3:18 am
    Johnny,
    Check out the Lowell Ego; it’s great for tabletop and other small subjects like your puppet, especially if you want to create a daylight-type look. Here’s the link:
    https://www.lowelego.com/
    JS
  • Dorel Iordache
    August 14, 2006 at 4:39 pm
    Thanks, John! I found a local distributor and I
  • John Sharaf
    August 14, 2006 at 5:54 pm
    Johnny,
    The Ego would be a good key light and depending on its placement will be either contrasty of flat, also use of fill card or even black “negative fill” card can control the contrast.
    Choose a small fresnel like a 100watt Pepper for the backlight, or enen a 6″ Kino Mini Flo.
    JS
  • David Jones
    August 14, 2006 at 10:47 pm
    Flashlights.
  • Dennis Size
    August 15, 2006 at 2:40 am
    Every reputable lighting company out there has very small 100w sources. Check out what’s available.
    Whenever I do “tabletop” and model work I use Dedo Lights (which come with a variety of accessories), Mini-Kino Flos, or ARRI Pocket PAR fixtures with their fiber optic tube attachments. I’ve also used a fiber optic illuminator as a single source and run up to six tubes out as my lighting positions.
    DS
