Activity › Forums › Lighting Design › Lighting for still images at a library?
  • Lighting for still images at a library?
    Posted by Anastasia on September 20, 2005 at 8:46 pm
    I am filming still images at the Library of congress with a GL1 canon.
    The images will be against a vertical metal wall.
    They do not allow direct lights.
    What is the best way to light this?
    John Sharaf replied 21 years ago 3 Members · 2 Replies
  • Jim Mulleder
    September 27, 2005 at 5:51 pm
    That’s simple…indirect lights!!! Sorry I couldn’t resist. What do they mean no direct lights? Can you just put diffusion on some direct lights, do they mean additional lights???
    I think you need a clear definition of no direct light because we all know, no lights…no picture!
    Jim
  • John Sharaf
    September 28, 2005 at 2:36 am
    I’ve encountered this dilemma several times in museums and libraries and it’s always worked out; sometimes you use the gain in the camera. other times you light very carefully to approved light levels (they read you lighting with a footcandle meter). Nowadays with slow shutter speeds and variable frame rate cameras (like the Varicam) you can shoots stills (or night exteriors for that matter) or any other non-moving subject at slow frame rates and shoot almost in the pitched black. Does your camera do that? If not beg, borrow or steal the appropraite unit.
    JS
