Activity Forums Lighting Design Lighting Control Assistance
  • Lighting Control Assistance
    Posted by Jim Bradley on January 24, 2012 at 10:46 pm
    Hello,
    I was wondering if someone could recommend a way to control 3 – 120-volt, 100-watt light bulbs. The light bulbs need to come on one at a time for one second at a time. This process needs to happen continuously 24/7/365.
    It is a simple process but the only thing that I have come up with so far is building a board with a controller and 3 – relays. That is about $100.00 worth of material and a couple hours of labor. I would like to do this project with less labor given the fact that there are 70 – of these to build.
    Thank you so much for the Help.
    Jim
    Mark Suszko replied 14 years, 7 months ago 2 Members · 3 Replies
  • Mark Suszko
    January 25, 2012 at 4:58 pm
    3 Ideas:
    Build it with an Arduino board and some relays, Arduinos are $30, their programming langage is open-source and the code you need is likely already written and posted for free.
    Or an old school 555 IC timing chip and $10 in Radio Shack parts will make a “Larson scanner”, the output of which can be sent to high-power relays.
    Or use a DMX controller from a Dj supply place to make lights “chase”?
  • Jim Bradley
    January 25, 2012 at 7:09 pm
    Hey Mark,
    Thanks for the friendly advice sir.
    Will any of these set ups be robust enough to run 24/7/365? Each of the 3 – light bulbs are pulling 100-watts at 120-volts.
    Best To All,
    Jim
  • Mark Suszko
    January 25, 2012 at 7:58 pm
    The circuit boards run on a 5 to 9-volt power supply, batteries or a wall wart transformer. The relays will have to be purpose-bought from an electrical contractor type store. They can switch house current, though the tripping signal to the relay may be very small. x-10 type relays are available online and maybe from radio shack as well: I don’t know what their rated cycle life is though. I would see if you can hire an electrical engineer or ham radio expert to solder one up for you to test. It might help to know what the final product/effect actually is. Are you making fake traffic lights or something as displays?
