Activity › Forums › Lighting Design › Lighting / booth grid with C-stands
  • Lighting / booth grid with C-stands
    Posted by Vince Becquiot on June 5, 2009 at 8:53 pm
    Could someone recommend a system that could work for us.
    Since we have a load of 8′ c-stand and the sand bags to go with them, I’ve been thinking of a safe / affordable way to build a lighting grid, as well as a sound booth for location work.
    We are only talking about 10 lights max all around (likely arri 1/2k and kinos), 4 pipes all around and one more above center.
    Any recommendations on piping and clamps?
    Vince Becquiot
    Kaptis Studios
    San Francisco – Bay Area
    Jb Letchinger replied 17 years, 1 month ago 3 Members · 2 Replies
  • Mark Suszko
    June 7, 2009 at 7:42 pm
    This may or may not help, but I am a huge fan of the Manfrotto Auto-Poles. These work vertically or horizontally, and you can add extensions to make the span a greater distance. In my youth, we used them extensively to throw up an “instant light grid” near the ceiling of a room without needing any light stands. Moreover, we could assemble our instruments on the floor, then lift the pole into place and lock it in. The things have a down side in that they don’t hold as much weight as a truss or a DJ’s lighting tree. but they are inexpensive and versatile, for all of that. We would hang maybe up to five Lowels on one sometimes.
  • Jb Letchinger
    August 23, 2009 at 5:37 am
    sound on location – VO… get some furniture pads and throw them over the C stands, with the arms at 90 degrees to the stands… add some grip clips… you can put these on 3 sides or so of the talent…
    as far as a grid… I’d refer you to the Gripping forum on the cinematographer.com board…
    https://www.cinematography.com/index.php?showtopic=40843
    and this thread in particular
    https://www.cinematography.com/index.php?showtopic=40221
    basically just buy or scavenge semi-lightweight pipe and bolt it to the girders in your ceilings… use hardware – not rope.
    autopoles are a bit pricey and C stands are not meant for this, will be unsafe, just get in your way, and be better used elsewhere.
    JB
    JBL Films, Inc.
    please vist
    https://www.jblfilms.com
    https://www.jblfilmsinc.com
