Activity Forums Adobe After Effects lighting a scene
  • lighting a scene
    Posted by Ross Kidd on October 16, 2008 at 11:01 am
    I want to create this scene in After Effects.
    https://welovethedesign.com/myscene.jpg
    The problem is I keep getting grey or black unlight areas when I use spotights (as you would expect).
    All I want is for each of the elements to cast a shadow and for the shadow to move but for the whole scene to be white.
    Many thanks,
    R.
    Mark replied 17 years, 10 months ago 3 Members · 4 Replies
  • Mark
    October 16, 2008 at 11:06 am
    try adding an ambient light and playing with the intensity.
    Mark
    Mark Harvey
    Senior Editor
    Le Réseau des sports
  • Ross Kidd
    October 16, 2008 at 11:21 am
    Tried that when the scene is less than 100% the edges of the spotlight show, at 100% ambient the shadow goes.
    I suppose I am just trying to emulate the sun. Is there a way to increase the diameter of the spotlight?
  • Gary Hazen
    October 16, 2008 at 11:44 am
    That scene doesn’t look lit. It looks like they faked the shadows by using additional layers for the shadow elements. Have you tried faking your shadows rather than casting them?
  • Mark
    October 16, 2008 at 11:51 am
    Gary,
    After thinking about this for a while, I was coming back to post the same answer as you….i guess you beat me to it 🙂
    And yes, you can increase the size of the spot by increasing cone size in the light settings dialog, and/or pull the light back in Z-space.
    Mark
    Mark Harvey
    Senior Editor
