Activity Forums Adobe After Effects Lighting 3D Precomps with Collapsed Transformations
  • Lighting 3D Precomps with Collapsed Transformations
    Posted by Shelby Miller on August 12, 2008 at 7:31 pm
    I’ve run into a bit of a problem I can’t seem to figure out and hope someone can help me.
    I’ve created several precomps consisting of animated (in 3D space) text and images. Those precomps are nested in a final comp over a larger background image onto which I want them to cast shadows.
    I have to collapse the precomps to keep the moves they have in 3D. However, it seems that my lights do not cast shadows from the precomps unless I deselect ‘collapse transformations.’ Then it works fine. But my moves are gone.
    I’m stumped. I’m using more precomps than I usually do and I’m not as familiar with the way comps behave when you collapse them. So any help would be greatly appreciated.
    Shelby Miller replied 18 years ago 3 Members · 3 Replies
  • Darby Edelen
    August 12, 2008 at 8:20 pm
    When you collapse transformations, the material options on the pre-comp no longer apply. The material options on the layers inside the pre-comp are used. So make sure that all of the layers in your pre-comp are set to cast shadows!
    Darby Edelen
    NVIDIA
    Santa Clara, CA
  • Wieger De leur
    August 13, 2008 at 9:26 am
  • Shelby Miller
    August 13, 2008 at 7:02 pm
    That worked. I had to travel back several nested comps to get to the original. I thought I had already selected Casts Shadows on all the layers, but I hadn’t. Thanks!
