To change the color of the shirt, you can use the secondary color corrector. Use the SELECT EFFECT RANGE pipet to select the color range you would like to change. Change the color in the secondary color corrector.
Selecting the SHOW MASK enables you to see the mask you produced. If you wish, you can improve the mask with the LIMIT LUMINANCE sliders.
If the color of the shirt is also present in other parts of the event, you can duplicate the track with the T-shirt and by using a mask you can make sure that the effect is only working on the T-shirt while the area outside of the T-shirt remains unaffected.
Ofcourse this works also if you don’t want to change to color of the T-shirt but only want to make it lighter. In that case you do exactly the same, but after selecting the color of the T-shirt, you play with the sliders for saturation and/or gamma.
Theo
