Activity Forums Adobe After Effects Light Trail w/ Particular
  • Light Trail w/ Particular
    Posted by Hans Meier on May 6, 2008 at 5:43 pm
    Hi everyone,
    I’m trying to create something like this:
    https://www.easyphotoupload.com/uploads/bc4d6b3b4c.png
    But it should be a solid line that moves around in 3D-Space…like the good old iPod Nano commercial, but not with a couple of lines creating the trail, but one single line.
    I’m stuck on how to use Particular. Should I use a Photoshop-Stroke for the Emitter and increase my number of Particles to achieve a solid trail – or should I use a light as an Emitter – or should I use the photoshop stroke as the particle-type?
    Does anyone get my point???
    Thank you so much…
    Hans Meier replied 18 years, 4 months ago 2 Members · 4 Replies
  • Nicholas Toth
    May 6, 2008 at 6:21 pm
    I get what you’re saying, but creating a still like that is just screaming to be created with FORM.
    I’d say make a couple different emitters on different layers if you want to go that route, and just layer them.
    There is more than one way to skin a cat!
  • Hans Meier
    May 6, 2008 at 7:00 pm
    Nicholas,
    don’t get me wrong…I’m not trying to create a still image…I need an animation…
    Cheers
  • Nicholas Toth
    May 6, 2008 at 7:03 pm
    Let me re-phrase
    That style of animation/look is begging, screaming, pleading, do be done with Form.
  • Hans Meier
    May 7, 2008 at 7:40 am
    So far I just did some playing around with form…but at this moment I can’t imagine how to animate a trail in 3D-Space the way I want it to animate. Because as far as I understood Form you are not able to animate the form itself, but only maps that are affecting the grid.
    But I’m pretty sure that I’m wrong…
