Activity › Forums › Adobe After Effects › Light Sweep CC on shape layer
Posted by Brandon Adam on August 13, 2014 at 10:02 pmHello CC,
Is it possible to be able to place a light sweep on a rectangle without it starting to show along the sides of the shape layer.
I want the edge intensity to only be visible from the top and not the sides.
John Cuevas replied 12 years, 1 month ago 3 Members · 8 Replies -
John Cuevas
August 14, 2014 at 2:25 amOne method would be to make a duplicate of you layer with the light sweep and mask to the areas that you want to be effected by the light. Like this: 7866_lightsweep.aep.zip
Johnny Cuevas, Editor
Thinkck.com“I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
—THOMAS EDISON on inventing the light bulb. -
Brandon Adam
August 14, 2014 at 5:45 am -
John Cuevas
August 14, 2014 at 8:43 pmDo you mean the light sweep, get’s a sharp edge? If that’s the case, just make your masking layer bigger.
Brandon Adam
August 14, 2014 at 10:17 pmIf I mask the duplicated layer with the light sweep, the mask then creates a “sharp line” between the light sweep and second shape layer. If I make my masking bigger it then starts to show the light sweep showing on the edge of the shape layer.
I have uploaded my AE. I may be doing it wrong!
7872_lightsweepmask.aep.zipThank you once again John.
Kevin Camp
August 14, 2014 at 10:51 pmtry this:
add the circle effect, position the ‘center’ in the upper-right corner area and set feather, radius, opacity and color as needed.
add linear wipe, angle = 0 and set completion and feather as needed to give the thickness as needed.
add cc composite, setting composite to behind and uncheck the rgb only option.
if you fiddle with the circle and linear wipe settings, i think you’ll get really close to the edge effect that you are looking for.
Kevin Camp
Art Director
KCPQ, KZJO & KRCW -
Brandon Adam
August 14, 2014 at 11:05 pmSorry Kevin, I’m not sure I follow through with your steps. What do you mean by “circle effect”?
Sorry, I’m still an amateur at this.
Kevin Camp
August 14, 2014 at 11:30 pmthere’s an effect called ‘circle’ — effects>generate>circle
Kevin Camp
Art Director
KCPQ, KZJO & KRCW
