Activity › Forums › Adobe After Effects › light strokes in form of a wave
  • light strokes in form of a wave
    Posted by Thea Birgit on November 20, 2006 at 5:20 pm
    hi it is rather hard for me to exlain
    I’m refering to
    https://psyop.tv/main.php and there to “propaganda” and then “sheryl crow”
    at the beginning of the video one could see some wavy light stokes going from left to right
    I’m not shure particular perhaps ?
    how did they do this ? I tried but I failed
    any suggestions ?
    greetings from munich
    Thea Birgit replied 19 years, 10 months ago 3 Members · 6 Replies
  • Julian Sixx
    November 20, 2006 at 5:52 pm
  • Mylenium
    November 20, 2006 at 6:29 pm
    Yes, Particular or 3DStroke. When using Particular, use only a few particles, emit them all at the first frame, but let them have no velocity at all. This way they will be “stuck” to the emitter position, which you can freely animate. Now all you need is to tweak their look and enable the Aux system to draw the actual trails.
    Mylenium
    [Pour Myl
  • Thea Birgit
    November 20, 2006 at 10:19 pm
    thanks Mylenium,
    it is now a little bit similar. my next question is:
    the solid with particular is fine – but I dont want to animate the position xy I woukd like that the partikels should start on a path I have drawn in illustrator.
    I imported the path into AE on a seperate solid and tried to connect with layer but there happens nothing.
    what is wrong ?
    thanks again
  • Julian Sixx
    November 21, 2006 at 5:28 am
    Hi
    use the new feature “Motion Path” in Particular 1.5
  • Thea Birgit
    November 21, 2006 at 11:43 am
    thanks for answering
    what I tried:
    light with the name: Motion Path 1
    solid with particular and the illustrator path which appeares as mask
    particular – physics – air: Motion Path 1
    BUT: how could I say to the light: follow my illustrator path ???
    thanks again
  • Thea Birgit
    November 21, 2006 at 12:29 pm
    Hi
    I found it. there is a really good tutorial from aharon:
    Importing Paths Into After Effects
    thanks all
