Activity › Forums › Apple Final Cut Pro Legacy › Light Streak Effect
Light Streak Effect
Posted by Colton Phiscator on August 23, 2010 at 8:18 pmAnyone know what filters I would need to achieve a lighting streak effect similar to this video…1:30 mark onwards…
Bret Williams replied 16 years, 1 month ago 4 Members · 6 Replies -
Shane Ross
August 23, 2010 at 8:41 pmWhat video?
Like this?
https://www.lucavisualfx.com/clips.htm
Buy these, layer them on V2 over the footage, then change the Composite mode (right click, COMPOSITE MODE) to SCREEN.
Shane
Read my blog, Little Frog in High Def -
Colton Phiscator
August 23, 2010 at 9:18 pmWhoops forgot the video…
Here…
https://www.youtube.com/watch?v=mqWq_48LxWQ&feature=av2e
Some contents or functionalities here are not available due to your cookie preferences!This happens because the functionality/content marked as “Google Youtube” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
Bret Williams
August 23, 2010 at 9:46 pmForget about the light ray effect, I’m curious about the effect at 4:07. Is that a plugin?
John Fishback
August 23, 2010 at 10:36 pmCheckout To Much Too Soon’s Flashframe. And, there are other FX in the package, too.
John
MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.8 QT7.6.4 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
FCS 3 (FCP 7.0.2, Motion 4.0.2, Comp 3.5.2, DVDSP 4.2.2, Color 1.5.2)Pro Tools HD w SYNC IO & 192 Digital I/O, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
Shane Ross
August 23, 2010 at 10:51 pmAH…different then film effects.
Shane
Bret Williams
August 24, 2010 at 4:29 amI saw some garbage overlaid with a screen or add mode, and a bunch or prism and lens flares. The latter possibly added in post, but I thought most of it looked like lens filters. I’ve seen shooters shoot through glass and prisms in foreground before.
OT: anyone see how they shot star trek? For a film that I thought was 95% CG it turned out that it was only like half CG or less. Even large interiors were real like the doctored up budweiser factory. And the lens flares were real, done by shining flashlights at the camera. The incessant camera shake was real. The director himself physically shook the camera magazine.
