Activity Forums Adobe After Effects Light shaft/beam work-arounds please.
  • Light shaft/beam work-arounds please.
    Posted by Jon Price on January 21, 2014 at 1:28 pm
    A few things to note:
    I working on an AE project whereby no plugins can be used. Please do not suggest the use of a 3D program to do this properly, I’m hoping for an AE work-around. Any help will be massively appreciated. Working in CS6. 🙂
    I am aiming to demonstrate way light refracts through a prism (https://images.fineartamerica.com/images-medium-large/9-light-passing-through-prism-david-parker.jpg).
    I have constructed a 3D prism by rotating squares and triangles – this exists in 3D space. I have set a spot light against the prism. However, I cannot see the origin of the light, not it’s ray/beam of light. I understand this is just the way it works in AE, only displaying the surface reaction to the light, but I would like a solution if possible.
    I have tried using ‘beam’ effect, but this does not appear to work within a 3D space (it flattens) and it doesn’t point from a distant position, to the prism in the 3D space.
    I would like to be able to animate the camera, from the flare of the beams source, travelling along and reaching the prism.
    I’m not looking for hyper realism, just a nice diagrammatical way to show it.
    Also, if anyone has any ideas how to best replicate the rainbow colours out the other side I would also be open to suggestions!
    Thanks in advance!
    Ridley Walker replied 12 years, 7 months ago 2 Members · 1 Reply
