Activity Forums Adobe After Effects light reflections on animated water surface
  • light reflections on animated water surface
    Posted by Posix6 on May 24, 2006 at 12:48 pm
    thanks to aharon rabinowitz’ great podcasts on displacement mapping i was able to create a text layer being nicely animated as if it was the surface of water.
    now to spice this up a little, i would like to add a light reflection effect, as if the sun was directly shining onto the water.
    it would be nice if the reflections were as intense as to create short flashes into the camera, according to the animation.
    i hope i managed to make myself clear.
    unfortunately, i have no idea how to go at an effect like this.
    maybe do some of you know sources of information? somewhere i could read or watch?
    or maybe is this thing easy enough to describe it in here?
    thanks in advance.
    Steve Roberts replied 20 years, 4 months ago 4 Members · 3 Replies
  • Fabiano Peres
    May 24, 2006 at 2:26 pm
    Hi there
    If the effect you want to create is the one I’m thinking, you just have to apply the plug in Starglow from http://www.trapcode.com and change the color to white.
    Take a look at the site, there is an example of water reflection…
  • Justin Productions
    May 24, 2006 at 2:39 pm
    Simply create a White Solid, then make a trapezoid mask shape over your water footage with the Pen tool (get it? so it would look like the sun is far away), then, simply play with the Blending Modes (maybe Add would be good). After that, you could play with the mask feather or add the Glow effect by adjusting the Glow Radius.
    Hope that helped.
    Justin Productions
    Tangerin01@hotmail.com
    Adobe After Effects 6.0 Professional
  • Steve Roberts
    May 24, 2006 at 2:49 pm
    Fractal noise, high contrast, animated, with glow added?
