Activity Forums Adobe After Effects Light Rays with Particular
  • Light Rays with Particular
    Posted by John Madison on February 26, 2011 at 2:20 pm
    Hi guys,
    I’m trying to create a specific effect. The idea is to have a light rays emerging from a layer, but in 3D space so that i can rotate a camera around this.
    I’ve managed to create something similar with particular. I’m using a text comp as a layer emitter with 1000s of particles. To get the effect of light rays I’ve added a directional blur (fast blur) on the particles. However, the blur works on both directions and so the rays extend downwards which is NOT what i want.
    I’ve attached an image to show you what i mean. There should be no rays extending below the text layer.
    Any way around this, or can i create the effect using a different procedure?
    Philippe Lessard replied 15 years, 6 months ago 4 Members · 5 Replies
  • John Madison
    February 26, 2011 at 2:22 pm
    Sorry! Forgot to add image.
    Here it is:
  • Tudor “ted” jelescu
    February 26, 2011 at 6:22 pm
    Play with the Visibility of the particles- adjust hoe far away they should vanish and how long the fade should be ( in your case the numbers should be the same).
    Tudor “Ted” Jelescu
    Senior VFX Artist
  • Chris Buttacoli
    February 27, 2011 at 6:33 pm
    Since I don’t see any shading going on in the BG, what about placing a same colored solid just under the text in 3d space to block out the blur spill from the cameras view.
  • John Madison
    February 27, 2011 at 7:57 pm
    The blur is not 3D. Putting a solid there doesn’t make a difference. I can put a solid above the particle layer but that blocks out the text layer aswell. 🙁
  • Philippe Lessard
    February 28, 2011 at 5:33 pm
