Activity › Forums › VEGAS Pro › Light rays text + background can’t find a way
  • Light rays text + background can’t find a way
    Posted by Sinja Joisha on February 20, 2012 at 3:55 pm
    I’m racking my mind trying to figure out a way to have the light ray animated sweep across both the background AND text layer, haven’t found a solution yet so could anyone give me a suggestion?
    Sinja Joisha replied 14 years, 7 months ago 1 Member · 1 Reply
  • Sinja Joisha
    February 20, 2012 at 4:39 pm
    Nevermind I figured out a way. Once you get the text made and put it on a track separately on top of the background you put the fx light rays on the background how you would want it to be animated. After that do the exact same thing for the text and it should be in sync to look like it goes together. I hope this helps someone out there who is trying to find the answer I had to come up with.
    One more thing is that if you have the ray position at the middle it looks like the rays are going up
    So put it at the top to make it face forward
