Activity › Forums › Adobe After Effects › light path guide
  • light path guide
    Posted by Jordan Mcgehee on February 8, 2010 at 9:06 pm
    Hey guys,
    I am trying to follow a tutorial to which the built in light in after effects is animated in 3d space. However in the tutorial the light when given to position key frames has a guide showing the path, and it looks like you can manipulate the path, mine however shows no path. What is wrong I have the toggle mask and shape path selected.
    Jordan Mcgehee replied 16 years, 7 months ago 3 Members · 4 Replies
  • Jordan Mcgehee
    February 8, 2010 at 10:32 pm
    I still doesn’t work even when I have it highlighted, by the wsy I have AE CS4, Mac Snow Leopard.
  • Brian Charles
    February 9, 2010 at 12:08 am
    Dave is correct, if you change the Preference settings for Display you can set the number of keyframes visible on a motion path.
    Two other things may be an issue:
    1) The type of light. Only point and spotlights have position that can be keyframed.
    2) You must have a minimum of 2 keyframes to make the motion path visible.
  • Joey Foreman
    February 9, 2010 at 5:30 am
    Be sure that in the View Options for your comp that Motion Paths is not unchecked.
  • Jordan Mcgehee
    February 9, 2010 at 2:46 pm
    Where is that?
