Activity Forums Adobe After Effects Light lines in 3d grid setup.
  • Light lines in 3d grid setup.
    Posted by Hans Van vliet on February 25, 2007 at 1:19 am
    Hey,
    This might be hard to explain but I’ll do my best. I am emulating the “jacob’s ladder” effect. I have 2 MAIN pictures that are 2430×1380 (1=Front, 2=Back) and I’ve cut out both pictures with 270×230 (9×6 grid) blocks. I have then married the Each Front and Back block into Their own (270×230) 3d comp (front 0,0,0) and (back 0,0,1). Then I have a 3d ROW comp that I brought in an entire row into (9 pieces) and then animated these to do the “jacob’s ladder” thing. I Then did all the rows and put all 6 of them together in a big comp DIALING in all the positions.
    On using this effect I get a seam issue where all the blocks have faint light lines through them all. I can see through to the background underneath it’s as if they are not lined up correctly. I can also see lightly through the pixel edges and it’s just frustrating… I have dialed in 0,0,.01 into the back pieces. Same problem .. Anyways, I have found a work around which is to place the MAIN pictures comps and fade them in after the ladders is complete, but it cheapens this effect greatly .. anyways, If anyone has suggestions or questions I would love to hear from ya ..
    Thanks in advance.
    ..::hunz
    Hans Van vliet replied 19 years, 6 months ago 3 Members · 6 Replies
  • Mylenium
    February 25, 2007 at 3:57 pm
    You can’t avoid that. It’s AE’s filtering on 3D layers. Only setting layers to draft mode can minimize the effect somewhat.
    Mylenium
    [Pour Myl
  • Sam Moulton
    February 25, 2007 at 5:17 pm
    try setting the blend mode to alpha add
  • Hans Van vliet
    February 25, 2007 at 10:21 pm
    Ahh well, I thought as much. Hopefully they upgrade this engine soon .. Thanks everyone.
    ..::hunz
  • Hans Van vliet
    February 25, 2007 at 10:27 pm
    Thanks for the suggestion, didn’t work but that’s ok .. I’ll get started on my work around. sigh 😀
    ..::hunz
  • Mylenium
    February 26, 2007 at 5:28 am
    [hunz25] “Ahh well, I thought as much. Hopefully they upgrade this engine soon ..”
    I wouldn’t hold my breath. If you’re serious about this stuff, learning a 3D program might be more efficient then turning prayer mills for AE.
    Mylenium
    [Pour Myl
  • Hans Van vliet
    February 27, 2007 at 6:17 am
    Yeah, I use 3dsmax as well and it looks like I’ll be shipping this routine over there instead .. thx again.
    ..::hunz
