Activity Forums Adobe After Effects light layers won’t work
  • light layers won’t work
    Posted by Michelle De long on February 23, 2009 at 8:38 pm
    Hi All,
    Taken over a pretty complex project and having trouble with a few composition.
    For some reason the light layers do not work.
    This project has previous drafts in previous compositions.
    So the comps I am working with now were copies of former comps and just had more things added at the tails. Nothing changed on the light layers.
    I take a look at two comps one with light layers working and one without and everything looks exactly the same. Same switches-positions-timing everything is exact.
    Cast shadows is on the light layers. Accept Light and Shadow are on the layers that get the lighting effect.
    I also tried to copy a light layer from a comp where it was working and paste into a comp where it was not working and no light effect come through the comp that light don’t work on.
    Is there something in the composition settings that I am missing?
    This is weird
    Michelle De long replied 17 years, 7 months ago 2 Members · 2 Replies
  • Roland R. kahlenberg
    February 24, 2009 at 5:46 am
    Weird! Could be something as silly as Draft 3D being switched on. Or check for 2D layers that may be interferring with the Light and 3D layers.
    Good Luck
    RoRK
    broadcastGEMs – AEPro Volume 02 (Professional Adobe After Effects Project Files – Now Available)
  • Michelle De long
    February 24, 2009 at 5:14 pm
    Thanks so much-it was as stupid as being in draft 3d.
    Thanks again!
    Michelle
    Mimi Productions
